Consumption at 30 miles an hour, 38 special
Hello in order to bring back a special baja 38 in one go, I would like to know the consumption of the engines per hour at 30 miles per hour. Thank you
Baja 38 Special with 2 mercruiser 502 mag mpi.
Thinking 30mph is going to be as slow as that boat will run and stay on plane.
He's suggesting you'll burn 13 gallons per hour per engine at that rpm, whereas the previous poster suggested 15 gallons per hour per engine (they are both close). You might find that hull needs to run more like 35-38 mph to be as it's most efficient.
Either way, figure 1 mile per gallon for your trip and you should come in having burned a little less than that.
Thanks, from Cannes ( France) to Perpignan, I have 230 miles.
So how many gallons I need to make this distance?
For you the best speed/gallons is 36-38 miles/hour.
So 6h30 time traveled.
So how many gallons for 2 motors?
Is that distance calculated going direct in a straight line to Perpignan after rounding Iles d'Hyeres or running the shoreline? If running just offshore there are several ports to refuel if needed....
Your fuel consumption will be higher with a heavier fuel load (more RPM to maintain same speed) so calculations are a bit of a sliding scale full of fuel vs. light...plan for a reserve % as a "just in case"
