Need tuning help >
Need tuning help
Need tuning help
Old 05-20-2020 | 07:07 PM
Question Need tuning help
Will I need less fuel , what about timing?
Can`t be too safe with THE RONA on the loose..
ICDEDPPL is offline
Old 05-20-2020 | 07:08 PM
Also with social distancing I want to be compliant so can anyone help with staggering a Flat Deck?
ICDEDPPL is offline
Old 05-20-2020 | 08:21 PM
wouldnt you need them on the exhaust pipes also? they say that breathing out is as dangerous as breathing in.
compedgemarine is offline
Old 05-20-2020 | 08:30 PM
endeavor1 is offline
Old 05-20-2020 | 09:11 PM
You do realize you need to run alcohol now, so that your engines internals are sanitized...
phragle is offline
Old 05-21-2020 | 08:04 AM
F-2 Speedy's Avatar
FF has a chain saw ??
F-2 Speedy is offline
Old 05-21-2020 | 08:22 AM
Originally Posted by f-2 speedy
ff has a chain saw ??
lol
PartyBarge22 is offline
Old 05-21-2020 | 08:36 AM
LOL
This is my helpful idea. First, you need two N95 masks. With the forced induction, you will want the built in blow off valve that the N95 offers. Second, as long as both engines are from the same household you should be fine with the social distance. Good luck and as always stay safe! This is my helpful ideas. First, you need two N95 masks. With the forced induction, you will want the built in blow off valve that the N95 offers. Second, as long as both engines are from the same household you should be fine with the social distance. Good luck and as always stay safe!
waterplay is offline
