Gasket sealer for Exhaust Manifolds. >
Old 11-10-2002 | 06:58 AM
Shooter's Avatar
Charter Member #300
Default Gasket sealer for Exhaust Manifolds.
My merc manifolds show a little sign of weeping on the outside which means it is or will be doing it on the inside - I miss my Gils. Anyway, going to yank them and put new gaskets in. Should I use a sealant with the gaskets and if so what kind of permatex? Also, anyone know the torque specs?
Thanx
Shooter is offline
Old 11-10-2002 | 08:22 AM
Ric232
Per the Merc service manual, the torque spec for the manifolds and risers 25 lb-ft. Be sure to use Merc OEM gaskets !! They are to be installed dry (no sealant).
Old 11-10-2002 | 02:50 PM
Cool
I use a Permatex product called "Hylomar"
RickR is offline
Old 11-11-2002 | 11:00 AM
pachangalpina's Avatar
If the sealing flange is pitted from rust/corrosion you may need to have the manifolds surfaced to keep them from leaking. You can surface them yourself if you have access to a large belt sander or take them to a machine shop.
pachangalpina is offline
Old 11-11-2002 | 11:07 AM
Shooter's Avatar
Charter Member #300
thanx guys, my friend also used a permatex product that was sprayed on the gasket. I don't think pitting is a problem, it's a 96.
Shooter is offline
ohmthis
3
08-01-2007 11:18 AM
502SCS
3
07-31-2006 01:57 PM
GoCiggie31
4
10-24-2005 11:49 AM
Shah Mat
2
05-26-2004 05:13 PM
patrick22309
2
04-18-2003 07:07 PM
