1 inch B1 spacer complete kit
Brand new 3 hours test time, did not work for me but it was a good thing i tried it.
the stock coupler was rubbing the upper case 15/16 spline either side of the circlip but only 7/8 inch shaft sticking out of the upper.
Before it was assembled and run
i test fit the new coupler it also had 15/16 spline on either side of the 2 circlips and it rubbed.
i trimmed the new coupler down so that it doesnt rub the upper case it now has 3/4 inches of spline on top.
the new preload spacer also had to be emery clothed to fit into the upper, it got scratched coming out.
I tried to photo document the scratches and how much the coupler needed to be trimmed down in length.
other than cosmetic on the coupler and preload spacer the kit is in excellent condition and will work correctly.
paid 400 for it a couple weeks ago take 250 plus shipping.
Stock coupler wear
Stock coupler wear
Where it was rubbing on the upper housing, zoom in, looks like an oring goes there.
Stock coupler trimmed to fit The stock coupler is not included in this sale
New coupler trimmed to fit
Top side 3/4 inch spline depth
Bottom side, 15/16 spline depth
Complete kit speedo oring speedo tube water & oil orings, qaud ring, coupler, preload spacer, 6 studs, 1 bolt, directions and the 1 inch spacer
Stock coupler wear
Stock coupler wear
When you get them off and figure out what you want for one of them let me know. I only need one bit of the price is right I may take them both. Send me a PM or call or text me at 727-992-seven six one four thanks
I believe I have $450 into them, so $400+ shipping?
