Replacement Heads for 454 Mag >
Old 08-18-2020 | 01:20 PM
Default Replacement Heads for 454 Mag
Cracked the exhaust seats on my cast 454 Magnum heads. Looking for a good replacement suggestion, Al or FE.
JonnyD757 is offline
Old 08-18-2020 | 01:21 PM
SB
Mark IV, Gen V or VI ?
Where are you located ? Shipping cast iron behemoths matter $$$ wise by how far.
SB is offline
Old 08-18-2020 | 01:44 PM
resurrected's Avatar
Closed cooling? Fresh water or salt?
Used or new?
Used, Sick Stinger on here would be the guy
resurrected is offline
Old 08-18-2020 | 01:45 PM
SE PA. Not sure what Gen the block is. They are rectangular port heads. Guy i bought it from said it was the Mercruiser 365 Mag 454
Old 08-18-2020 | 01:51 PM
Fresh Water, may see salt once or twice a year. Looking for new if possible
Old 08-18-2020 | 02:48 PM
Is ADK61 still around? He was selling complete heads well set up for marine use. I believe the feedback was consistently positive, which is rare in this industry.
Baja Rooster is offline
Old 08-19-2020 | 01:12 AM
If it has a fuel pump mount location on the engine block, it is a Mark IV.
If it does not and has stamped steel timing chain cover, it is a Gen V. Also if the head casting numbers end in 088, they are Gen V.
Griff is offline
Old 08-19-2020 | 06:34 AM
Rookie's Avatar
FE = Engine Quest heads (direct replacement)
AL = Promaxx (economical good aluminum head)
Get in touch with JimV on the board and he can set you up.
Rookie is offline
