1988 Chris craft stinger 260 >
Old 08-26-2020 | 01:19 AM
Default 1988 Chris craft stinger 260
Here is my never ending project, new transom, new paint and some bottom blueprinting.
Old plywood removed and 5 layers off 450gr added.
fitting the New plywood.
New Birch plywood in press. Bottom soda blasting
Ready to cut the hole, 17.5" X-dimension.
Ready to install stringers, engine mounts stil missing
JaniH is offline
Old 08-26-2020 | 05:16 AM
Any progress is progress. How long have you been working on it and did you ever have it on the water?
Ratty206ls is offline
Old 08-26-2020 | 06:45 AM
Bought the Hull without engines. Started 2 months ago.
JaniH is offline
Old 08-26-2020 | 10:10 AM
Nice work!
SignatureSuperCustomHawk is offline
Old 08-26-2020 | 10:54 AM
Is that bracket coming off transom assembly for locating motor mounts, if so that’s pretty neat. I imagine someone could make something like that for every boat that stringers are getting chopped out of even if not going from twin to single engine. Post more pics as you go, seems like it’s coming along nicely
Old 08-26-2020 | 11:28 AM
Fitting stringers
JaniH is offline
Old 08-26-2020 | 12:17 PM
that bracket is merc engine install tool, it has sliding shaft wich is pushed thru the gimbal bearing and liners thru the inner assembly plate.
JaniH is offline
Old 08-26-2020 | 02:55 PM
Looks very nice lot's of attention to detail,
i would like to see one of those stringers turned upside down to see what they look like and how thick they are.
how many layers of tabbing to install?
everything looks nice keep the thread updated with plenty of info and pics.
someone was looking for that tool a couple days ago, i know its for locating the mounts but i like the idea of having a jig to set the stringers in the boat plumb level and sqaure.
outonsafari is offline
Old 08-27-2020 | 01:42 AM
sides 6mm thick, 8mm thick on top.
JaniH is offline
Old 08-27-2020 | 04:02 AM
Bottom has 3mm deep hook in the first 6 feet from the transom, starting from inner lifting strakes, allmost to bottom of the V.
JaniH is offline
