Starter Issues >
Starter Issues
Starter Issues
Old 09-01-2020 | 08:06 PM
Default Starter Issues
Having problems with the starter on one motor. Blew the first one several weeks ago, Took all teeth off the bendix, cracked the housing on the nose, and put a slight bend in both bolts It started 4 times and is blown again. We will pull it tomorrow but expect the same.. Engine is a built Hawk 525SC with 8.5 to 9.0 compression. It does have CMI Headers with dry pipes. We seem to have negated the thought of hydro-lock as plugs are all identical and look normal, no water in the oil or cylinders, it has never hesitated to start , it fires instantly no hesitation like a stuck solenoid etc. it does make an intermittent noise like a chirp or screech that goes away as soon as it fires when starting and the next time sounds normal right up until its blown. Flywheel looks perfect. Thoughts, ideas???
RBeyer is offline
Old 09-01-2020 | 08:24 PM
Timing?
sailtexas186548 is offline
Old 09-01-2020 | 08:41 PM
Originally Posted by sailtexas186548
Timing?
Locked at 32 with Daytona Box. it cranks super easy. And then it doesn't
RBeyer is offline
Old 09-01-2020 | 09:21 PM
Rookie's Avatar
Do you have start retard activated in the box?
Rookie is offline
Old 09-01-2020 | 10:00 PM
I will confirm but they were set up by Tyler Crockett on the dyno.. I'm goigt to say yes. it also was fine for about 20 hours before this happened.
RBeyer is offline
Old 09-02-2020 | 07:16 AM
Is the starter shimmed correctly?
kvogt is offline
Old 09-02-2020 | 07:54 AM
SB
If the heavy old style block mount starter (ir: not mini high torque delco pg260) that uses a brace, but no brace installed, can do this.
SB is offline
Old 09-02-2020 | 08:43 AM
It is the high torque
RBeyer is offline
Old 09-02-2020 | 08:45 AM
It was not shimmed prior to the freshening of the engines and we rebuilt the same starter. We are going to check that this time for sure. It does not have the noise that usually accompanies a shimming issue,
RBeyer is offline
Old 09-02-2020 | 08:59 AM
F-2 Speedy's Avatar
Are they MSD ?
F-2 Speedy is offline
