K-Plane restoration >
K-Plane restoration
K-Plane restoration
Old 10-14-2020 | 05:40 PM
Default K-Plane restoration
Have fit 280T K-planes to ski boat, although had to cut down the transom mounting plates, and fabricate new stainless actuator mounts (which not sure whether to polish, chrome, or paint )
need to decide whether to powder coat, polish the aluminium or 2-pak the K-planes
How well do they stand up to paint or powder coating
still undecided on colour of hull
whats suggested ?
brett fiddes is offline
Old 10-14-2020 | 06:44 PM
Rookie's Avatar
I single stage painted my tabs and drives in 2010 and they held up great. I have seen an instance that powder coat has came off in a sheet on a drive.
Rookie is offline
Old 10-15-2020 | 12:46 AM
Powdercoat or paint will hold up just fine. Both have plus' and minus'.
You really should not powdercoat the rams unless you disassemble them though.
Griff is offline
Old 10-15-2020 | 03:25 AM
the transom plates were corroded around the actuator mounts, so when reduced in height to fit transom position the plates don't look to bad, had to redrill the 2 holes into transom plates, and weld up the hydraulic trim bolt holes
not sure whether I'm going to replace the seals in actuators, they look fairly easy to do if I can order the correct kit
There are few marks on ram bolts, however polished the shafts with 1500 grit
I might give the painting a go
cheers
Brett
