Inlet air temps on a turbo engine vs a blower engine
Was wondering which has the coolest air temps.
say at 5lbs of boost in a
1) twin turbo set up
2) roots blower set up
3) Whipple screw blower set up
does cooler or hotter air entering the motor increase or decrease the chance for detonation?
i realize that the cooler the air, the denser the air, the more hp you will make. Just not sure if it has an effect on detonation and combustion temperature.
thanks in advance for any info, RM
Assuming you aren't using an intercooler, if you are than the heat increase between different systems would be negligible at 5 psi of boost. The turbo setup should have slightly lower air temps than the Whipple (screw) style blower but both will be a fair bit less than a stanrd roots style blower. At a low level of boost 5 psi you will not see a huge difference in temp between any of them but the roots will still be hotter. With all that being said if your goal is to run 5 psi any method of adding power should be fine as there is not excessive heat created at low levels of boost. Anything from 8 psi and below should be fine, assuming you can get good gas on the water.
I have all my tools here and mig and tig welders For building my cars and 4x4s.
my buddy has some cool autoMagic welders for welding tubing etc. I’d like to sell the complete turbo kits if it performs well. He currently sells all kind of crazy frames and parts to make drag bikeS that run on 30 hp Honda equipment engines that started life at 6.5hp lol.
all we have to fabricate is the turbo mount that bolts to someone else’s LS marine exhaust manifold and fabricate the tubing for the turbo plumbing and make the tails so it will fit in a side by side application and feverything else I can buy.
I remember the Renault 1.5L 4 cyl turbo engines from the 80s in F1. They made 1247 hp for qualifying and 900+ in race trim I’m only looking for just over 2hp per ci.
If I'm not mistaken,there is a member on this site with a turboed ls. I think he has it in a platoon boat. Try doing a search.
