496 power steering pump
Looks like the newer model 496 which was part number 865710T which is NLA
The older model remains available (806230T) and uses pulley 862751
https://www.mercruiserparts.com/bam/...1816/11414/230
Don't know for sure but if you select the part link the dimensions list
4.65 x 1.75 x 5.88
Most likely the worste that would happen is need a different length belt
https://www.mercruiserparts.com/862751-pulley
4.65 x 1.75 x 5.88
The pumps pictured above are GM Type II (Saginaw TC series)
OP , .750 = 19mm
So, fir a search on the net type in GM Type II 19 mm shaft
These pumps have replaceable psi/volume regulators, so make sure to install what was on your pump.
OP , .750 = 19mm
I purchased this one recently was quick shipping and flawless.
https://www.ebay.com/itm/282628541247
