5252 EFI Flush Pro
Has anyone had a positive, negative or any experience with using a Flush Pro kit with 525 EFI's? I'm adding Whipple's to the motors and I would like to put these on however I'm a little concerned about water restriction.
Rick
Rick
That's probably best. There is just so little room in this boat, I have no idea where I could mount the ball valve where it could be reached. Although, if they need to be changed every 3 years that's probably far worse that jimmying a handle. Thank you very much for the input!!
