2 questions - O2 bungs and Jesel Rocker replacement
Got a couple winter projects:
1. I believe I've typically seen O2 bungs welded into the header, but if I have CMI big tube dry pipes would they weld them into the tail? I'll call CMI Monday but just figured I'd get some input here. Prepping to go to FI....
2. I've got the aluminum jesel rockers and they are breaking so going to go to steel. What is the difference between the sportsman steel, and the pro steel? I have the aluminum ones with the stands which I understand are compatible with the steel (same architecture). Best place to buy? Easiest just to buy direct from jesel or can I save a few hundred bucks going to a retailer.....
Does the Holley Sniper require O2 bungs on both cylinder Banks?
