removing a 12" ext box >
Old 11-14-2002 | 06:33 PM
Default removing a 12" ext box
i have a 1998 25 active thunder w/ 500hp and a stellings 12" ext box. the boat porposis bad, i was told the 25 thunder does not need a ext box to short of boat. my question what to do to remove the box. i have ext steering. any help would be great.
also will be selling the box cheap.
rssteiny is offline
Old 11-14-2002 | 07:48 PM
I would be interested. Where are you in PA?
cobra marty is offline
Old 11-14-2002 | 09:40 PM
crmax's Avatar
Im looking for a box also, I could give you a hand doing the switch let me know
crmax is offline
Old 11-15-2002 | 02:10 AM
puder's Avatar
speel chekk this fokker!
is it a nuetral box or does it raise your w dim??? I might be interested.
Pardon me, while I whip this out!
puder is offline
Old 11-15-2002 | 10:23 AM
mcollinstn's Avatar
Stelling has 3 holes to use - plus 1, neutral, and minus 1 - all with the motor in the stock location.
Somebody once told me that you can raise the motor an inch and then use the plus 1 holes tfor a total of plus 2. You can't go higher than that using a Stellings without plugging the transom. Again, this is what I have HEARD, no experience with them.
mcollinstn is offline
CFD5
Apache
4
12-07-2004 05:49 PM
Active Mike
15
11-25-2003 04:30 PM
dencam7
1
11-19-2002 12:52 AM
