Daytona Sensors Ignition Install >
Old 02-27-2021 | 09:45 AM
seafordguy's Avatar
Default Daytona Sensors Ignition Install
Where have you guys mounted the ignition coil? I've ordered the CPPerfornance mount for the back of the Stbd head but was looking for some pictures of where you have mounted the coil.
I have the mount across the back of the engine that has the main wiring harness, start solenoid and breaker. Don't want to relocate that. I have some thoughts but wondered what you guys have done....
seafordguy is offline
Old 02-27-2021 | 07:23 PM
Same way I did the crane ...
ICDEDPPL is offline
Old 02-27-2021 | 08:28 PM
seafordguy's Avatar
So I bought this one from CP, but looking at yours I think I'll just have a small piece fabbed to go up and over the box and the coil can sit up top on a "shelf"
https://www.cpperformance.com/p-1327...g-bracket.aspx
Old 02-27-2021 | 08:41 PM
i mounted mine under the bracket
snapmorgan is offline
Old 02-28-2021 | 10:52 AM
I think I still have the coil mounts if you need , I can look in my garage
ICDEDPPL is offline
Old 02-28-2021 | 11:08 AM
SABER28's Avatar
i made mine. just gave the drawing to a metal shop with a plasma cutter. think they were about $20 a piece done in stainless. bolts to the bellhousing upper row of threads.
SABER28 is offline
Old 02-28-2021 | 02:41 PM
Very nice! What kind of power and speeds you running or are those recent upgrade pics. I really liked my saber! I didn't want a single 28 but the deal just kind of happened when I wasn't looking. Where is the one at that was an early 90's twin that was out of the grand haven area. I remember somebody got a killer deal on it.
getrdunn is offline
Old 03-01-2021 | 06:53 AM
resurrected's Avatar
I made a plate to mount the box vertically with the coil beside it
resurrected is offline
Old 03-01-2021 | 09:50 AM
I mounted my box on the transom to reduce vibration and heat and the coil on a plate on the back of the starboard cylinder head. Both are on isolators.
ThisIsLivin is offline
Old 03-01-2021 | 01:36 PM
SABER28's Avatar
640 dynoed hp. 557 cid. i gps at 92 . props and a low drive height dont help me.
i'm not sure which one you are talking about. i bought mine new in 1998
SABER28 is offline
