Help with props on 37 GTX >
Old 03-08-2021 | 03:11 PM
Default Help with props on 37 GTX
Hi.
Hopeing you could help me with some advice on props for my Ol 37 GTX
I am in the middle of a mild restauration of a new to me 37 GTX and was wondering if you could advice me on where to start and what the hull likes. I have new build engines 614 cui with 14-71 blowers, the dyno sheets says 1000hp @6000 rpm and 1000lbft @ 4400rpm. For drives I have invested in arneson with 1.32 gears.
I did stumble over an old thread where a user named “thunderusone” had a 37 stiletto that many was comparable to mine, tried to pm him but no luck.
I live in Sweden and cleaver props like this is not that common so I have to order everything from the states without return policy.
Peter Oberg
Sweden.
Peter Oberg84 is offline
Old 03-10-2021 | 09:28 AM
32-33 pitch 18 degree 17.5-18 diameter is where you will be with that power and gear ratio
try Cobra power for used props. They have a prop swap program with what they have available
47EXCALIBUR is offline
Old 03-10-2021 | 01:33 PM
Ok. Thanks!
Old 03-23-2021 | 09:39 AM
If it’s the one I’m thinking . Look for an old performance report that was done in Powerboat magazine , would likely have the props originally used for your application.
notda1 is offline
