k plane instructions >
Old 03-09-2021 | 06:23 PM
Default k plane instructions
Does anyone have a manual or instructions on k plane installation or where I can get one.
Jeff
Zinger is offline
Old 03-09-2021 | 06:27 PM
Jeff
What do you need to know?? there is not much to them. Ask away.....
phragle is offline
Old 03-10-2021 | 07:14 AM
The mounting height and location along with how thick the transom needs to be and a wiring diagram.
Zinger is offline
Old 03-10-2021 | 08:34 AM
Wiring diagram is the same as trim pumps, blue (sky) up, green (grass down). all transoms should be pretty much the same thickness.
your biggest variable is if you want to mount them horizontal or mount them parallel to the bottom. and that is not really covered in any instructions and is more relative to whatever boat you are putting them on.
And DONT 5200 them on,,,,,,
phragle is offline
Old 03-10-2021 | 01:15 PM
95% are mounted parallel to the bottom. Mount them 3/4"-1" above the bottom.
Griff is offline
Old 03-10-2021 | 03:28 PM
Mbam's Avatar
Offshoreonly Advertiser
It actually should be opposite on the tabs. The high pressure side = blue = down for tabs
With you on the 5200 however I will say West Marine has a product called Debonder that is magic.
Mbam is offline
