Identify drive/Check drive oil... >
Old 04-18-2021 | 10:41 AM
Default Identify drive/Check drive oil...
My (new to me) drives do not have serial #s printed in the stripe on the units. I am trying to determine if there is a serial # stamped somewhere so I can identify the lower unit and then figure out how to check/service the drive oil.
My last set of Bravo drives had the drain plug behind the prop and a fill on the top side and a dipstick on top. My current ones have a Hardin Sport Tech Outdrive Cooling Shower on top and I did not want to introduce any more variables by removing/loosening it to see if there was a dip stick underneath.
THANKS!
F14A water jet is offline
Old 04-18-2021 | 10:46 AM
F-2 Speedy's Avatar
Isn't there a drive lube bottle mounted on the transom in the engine bay ? post a pic of the lower
F-2 Speedy is offline
Old 04-18-2021 | 11:30 AM
My last boat did not have a transom mounted drive lube bottle...I will look for one on this boat.
Lower unit attached.
THANKS for the quick response!
Old 04-18-2021 | 12:17 PM
There is no dipstick. The drive lube reservoir tells you if they are full
Griff is offline
Old 04-18-2021 | 12:24 PM
No drive lube reservoir on the transom that I can see.
F-2 Speedy's Avatar
looks like a standard swept back B-1, drain plug will be behind the prop
Old 04-18-2021 | 12:26 PM
F-2 Speedy's Avatar
it could be mounted on the engine ?? what engines are in it
Old 04-18-2021 | 01:21 PM
Redone motors (before I owned her)...489's
Can you see anything...
Old 04-18-2021 | 01:26 PM
And is there a top vent screw and/or dip stick (under my drive shower)?
Old 04-18-2021 | 01:38 PM
Found it...I was just looking from the wrong angle...
