vessel view on Garmin and Raymarine! >
Old 04-20-2021 | 12:57 PM
Default vessel view on Garmin and Raymarine!
https://www.mercurymarine.com/en/us/...ine-displays-/
This is great news to be able to get away from Simrad displays!
30outlaw is offline
Old 04-20-2021 | 02:24 PM
wondering if they will update firmware on older garmin units so they will have the same capability
poulsen11@yahoo. is offline
Old 04-20-2021 | 05:57 PM
If they did that, you wouldn't buy a new one
SabrToothSqrl is offline
Old 04-22-2021 | 07:40 PM
depends on "older" i would say at least need n2k.
30outlaw is offline
Old 04-23-2021 | 12:12 PM
Dave M's Avatar
Veteran: Navy
What is the difference between this and the NMEA 2K gateway? That's what I am using now along with smartcraft gauges.
Dave M is offline
Old 04-23-2021 | 01:11 PM
well disclaimer I am not an expert nor associated with anybody just my personal projects and research....
the gateway took smartcraft data and put it onto a n2k network so any mfd could have engine data using that mfd's generic gauge interface. biggest downfall here is you get generic faults if any at all
the vessel view link was for mercury/simrad/Lowrance/bg mfd's ONLY and gave you the actual mercury vessel view gauge interface and the big advantage here is faults, vessel view interface will give you the fault description (ex. engine misfire cyl 8)
the new connect appears to be like the vessel view link just for Garmin and raymarine mfd's
I did a pretty extensive upgrade from gauges to all mfd's on a boat recently and went with simrad for the very reason to get the oem mercury interface/vessel view software. had this been available I for sure would have went a different route with the displays! I don't think simrad displays are bad nor am I not happy with them, there are just better displays out there.
30outlaw is offline
Old 04-24-2021 | 09:41 AM
thank you for giving real life knowledge. Should have done my own research. Thought this was a software upgrade, but turns out it is a hardware upgrade. Of course in true to form fashion nowhere can you get pricing info nor can you purchase without a dealer.
Old 04-24-2021 | 10:12 AM
it was announced just a few days ago, give it a little bit... Given the fact that it does about the same thing as what the vessel view links, I would have to assume on the hardware side it’s going to be in at $1500 ballpark
30outlaw is offline
Old 04-26-2021 | 02:59 PM
So, I'm currently installing a Garmin 9" MFD and intrigued by the SmartCraft Connect. Did a little digging and came up with this:
Product data sheet:
https://samerwebapp01apncus01.azuree...730_scc_ss.pdf
Manual:
https://samerwebapp01apncus01.azuree...way_manual.pdf
Checking local dealer to get a cost and availability.
Holy Smokes is offline
Old 04-27-2021 | 07:26 AM
Product data sheet:
Manual:
smartcraft_connect_gateway_manual.pdf
they are available and in stock and right on par with the vessel view link $1199 retail when I called my local dealer.
30outlaw is offline
