Scored / Grooved Gen 7 Sea Water Pump >
Old 05-25-2021 | 07:53 AM
SB
Default Scored / Grooved Gen 7 Sea Water Pump
There appears to be several repair kits out there with wear plates.
Which have you used and prefer ? Why ?
I am dealing with 1 pump that has wear (a groove) on the body, not end plate.
SB is offline
Old 05-25-2021 | 08:15 AM
496 brass gen 7 water pump. repair kit for badly damaged pump body. If your brass body is badly grouved and fails to pump. our kit makes pumps work again without buying new pump. Rubber Impellers W/P Mercruiser Impeller Repair Kit $24.95. IMPELLERS W
I've been using these kits since 2014. Once you purchase the wear plate kit you only need to buy the impeller from then on out. My stainless wear plates look great. I change impeller every 2 seasons. 100 or so hours. Impeller looks fine and could easily go a 3rd year.
Ryan00TJ is offline
Old 05-25-2021 | 08:35 AM
SB
Thanks Ryan.
I did some reading on those. Some early versions had impeller separation issues. Seemed like it was fixed but on another boat site just this past week, a new impeller of theirs separated.
SB is offline
Old 05-25-2021 | 08:38 AM
SB
SInce I’m dealing with just the shaft side end being grooved, wonder if I csn install just that plate with stock impeller ? That doesn’t right but worth the question I guess.
SB is offline
Old 05-25-2021 | 09:01 AM
No
If you look around there are 2 kits, one has a gasket/shim spacer so you can use the stock impeller. I just kept the shim and replaced this kit every couple years so you can use the stock impellers.
Or say fk it and just buy a new pump housing and reuse the pump cover with the stainless plate.
Keith Atlanta is offline
Old 05-25-2021 | 09:21 AM
SB
After not finding anything definitive last night, about gave up and thus figured start this thread, I started another search and just found this - and factory parts !
Mercury-Mercruiser 47-8M0137219 Heavy Duty Sea Water Pump Impeller Kit
Mercury Marine 47-8M0137219 Impeller Kit.
Features:
Number of Blades: 8
Impeller Diameter: 2-5/8"
Impeller Length: 2"
INCLUDES:
(1) - 8M2021987 - Formed O-Ring
(1) - 8M0103389 - 0.030 in. Shorter heavy Duty Impeller
(1) - 8M0072979 - "Overmolded" Inner Wear Plate
Mercury Quicksilver OEM Water Pump Impeller Wear Plate 47-8M0137219 47-8m0120891
Quicksilver 47-8M0137219 Heavy Duty Seawater Pump Impeller KitIncludes shorter heavy duty impeller and over molded inner (front) wear plate for use when the front of the seawater pump impeller housing is worn due to debris.
Fits 2000 & newer MCM V-6 & V-8 (305, 350, 496 & 502 cid) engines with the brass sea water pump excluding Mercury 4.5L & 6.2L models.
SB is offline
Old 05-25-2021 | 11:11 AM
Been trying to get a hold of these guys for weeks. Voicemails and emails with nothing in return. I gave up.
BIGSLOW is offline
Old 05-25-2021 | 11:38 AM
SB
Originally Posted by Keith Atlanta
No
I don’t remember seeing that. Could you help me ? Search for this stuff has consumed mega hrs. Lol
SB is offline
Old 05-25-2021 | 01:53 PM
I hit the Louisiana fishing link shown below at the website and at that page get the second snip. Same guy??
The repair kit website has a bunch of dead links and missing photos. Seems poorly maintained.
cheech is offline
Old 05-25-2021 | 01:56 PM
SB at this point why not the Mercury kit?
Also, did that pump exhibit low water pressure? Or just PM?
I think mine were way worse than that last time I was in them. No pressure issues yet.
cheech is offline
