Oil filter Question - Since I have not seen one in a while
Recently, (I don't know why), I started doing some reading on oil filters, and have not seen many posts in a long time. Anyway, I have always run mobil 1 15W-50, or Lucas 20W-50 with Wix 51060R filters in my small blocks. Dart blocks - dual remote filters in series - no bypasses anywhere. Engines run close to 6000 RPMS and I have 10% over volume pumps and bigger pans, I know the wix filters down to 61 microns, but flow 28 GPM. I was considering trying out the Royal Purple 30-1218 to filter the oil a bit more.
Royal purple tech indicated that they do not measure flow, or could not provide a number, but measure pressure drop @ 20 GPMs. (4 PSI drop with their filter, versus a stock gm filter at a 10 PSI drop). bur filter to below 20-25 Microns.
At 6000 rpms, the oi pump pumps 21.45 gals per minute & flow is just as important as pressure.
Has anyone run the Royal purple 30-1218 - any issues ?
Just wanted to keep as much oil flowing as possible. Or am I overthiking this, and should just stick with the Wix 51060R ?
Thanks,
Ratchet
Thanks,
Ratchet
There are a quazzillion circle track and road race sbc’s using one (vs two) of the filters the OP is using.
fun facts: the 1060R has a anti drain back valve. The 1061R does not. Otherwise, they are pretty much identical.
Wondering if any of you boat guys use the System 1 filters ?? I try to get racers to use them because you can open them up after each race and check for any bearing material etc. They are expensive but you only buy them once. The filter elements are cleanable and can be easily inspected at each oil change. They have them in all popular sizes and a couple of different micron ratings.
Just curious.
https://system1filters.com/product/b...una-o-rings-2/
Just curious.
Surprising no commets on RP filters.
Prolly stay away from ?
System ones look nice, but if I go with 4, I can buy 90-100 Wix or similar filters. Maybe I will look into these on another build
