block paint
what paint are you guys using to paint the blocks and heads? I just replaced my SBC block out of my donzi and the heads where cleaned. I see they have a couple different paints like the mercusier phantom black and the 3 step paint as well. Which one of these are you guys using? Thanks in advance. Hoping to get the boat in the water before july 4th weekend!
I used black high-heat gloss engine paint (rattle can) on the block and a high-heat rubberized coating over paint on my oil pans to repel water and prevent rust. I also do brush-on touch-ups before dropping in (something always gets scratched).
The most important thing is prep. I clean the block and use a pain prep solvent before I prime it. I used etching primer and Phantom Black this time. I got it fairly cheap... We'll see how it holds up.
