Keith Eickert still in business for parts? >
Old 08-23-2021 | 10:22 AM
bck's Avatar
bck
Charter Member#568
Default Keith Eickert still in business for parts?
Need a new body for one of his raw water pumps. Phone # on website goes to voicemail, no part numbers or prices on website. Plus didn't he sell his business / name at one time then start over again? Any contact info would be helpful. Thanks.
Straight bottoms and flat decks
bck is offline
Old 08-23-2021 | 10:39 AM
SB
Did you try this one ?
https://keautoandmarine.com/
SB is offline
Old 08-23-2021 | 10:45 AM
bck's Avatar
bck
Charter Member#568
Yes. That's the site I got the phone # from. I found a pump that looks like mine but it's not a great pic. It's a fla number and I thought he relocated in the midwest somewhere
bck is offline
Old 08-23-2021 | 11:05 AM
SB
Yes, with Onken years ago. I thought that folded too ? Maybe not ?
https://www.lakeexpo.com/news/lake_n...a4bcf887a.html
Lightning Performance Group
Easton, Illinois
309.562.7474
SB is offline
Old 08-23-2021 | 11:10 AM
Team Archer's Avatar
the pumps that Harden and CP Performance sell are the same pump I far as I know I used there body's to replace some old nylon pump body's that were on some old Eickert class one motors they worked great. Regards Dan
Team Archer is offline
Old 08-23-2021 | 11:21 AM
PM'd
LSXCJ is offline
Old 08-23-2021 | 11:42 AM
If its this pump in the pic and the housing and shaft are good you can rebuild the pump with new bearings and seals. I ran these pumps on my skater and i use to rebuild them when the bearings went bad. Bearing #6204RS Seal# 20.32.8 you can get them from Buffalo Bearing. If the housing is cracked or beat up you can get the new housing its a new design i ordered one awhile back.
raymo1979 is offline
Old 08-23-2021 | 11:53 AM
bck's Avatar
bck
Charter Member#568
that's the pump. It sucked something in and there is plastic melted onto grey housing. Doesn't really want to come off and I know I'll gouge it up pretty good if I can remove it at all. I was looking to replace just the pump body.
bck is offline
Old 08-23-2021 | 11:56 AM
bck's Avatar
bck
Charter Member#568
I'll take a look. The pump is the one pictured above. Not sure how old that model is but it came directly from Keith a few years ago as a new pump. Is that the one you were thinking of Dan?
bck is offline
Old 08-23-2021 | 12:06 PM
Did you call peterson? They sell the parts for Keith 512-296-3434 Last time i bought the housing it comes with the new shaft because its a new design.
