Pushing the spark plug leads between the header, any trick?? >
Old 09-14-2021 | 03:59 PM
Question Pushing the spark plug leads between the header, any trick??
On my 454 with CMI headers, really easy non-issue just push.
But on my HP500 with factory headers, I can barely touch it, I reach under and push with my thumb. What tricks or tools can I use to push it on, so I feel the click?
And with new mercury wires, do you ever have to adjust the clip inside so it is tighter on the plug? I feel the click, but they feel slightly loose when on.
2Slow4me is offline
Old 09-14-2021 | 04:05 PM
F-2 Speedy's Avatar
use a small amount of dielectric grease, I have 6 or so that are a real pita
F-2 Speedy is offline
Old 09-14-2021 | 08:37 PM
I’m guessing you have Gil exhaust on the HP500. They stuck to do plugs on and it’s all by feel. I just put new Merc plug wires on my engines with CMI’s. They all were pre greased. Just used a Qtip to spread the grease around better. None felt loose when installing them.
Griff is offline
Old 09-20-2021 | 12:14 PM
Thanks very much guuys! Never used dielectric grease on it, that will make it easier. (and yes they are the GIL headers)
I have seen these pliers advertised, anyone try anything like this?
Here is the description:
Spark Plug Pliers by Lisle support two pulling positions that help make removing spark plug wires a safe and comfortable job. Its specially shaped, cushioned jaws grip the boot straight on or from the side. Plastic handle grips of pliers help prevent shock.
  • Lisle LIS52990 spark plug pliers make removing spark plug wires a safe and comfortable job
  • Cushioned jaws for comfortable grip
  • Plastic handle grips help prevent shock
  • Easy to use
And this is the link
https://www.homedepot.com/p/Lisle-Sp...2990/306763961
2Slow4me is offline
Old 09-20-2021 | 12:57 PM
  • Easy to use
I have a set of spark plug boot pliers that have an offset to them. They work fantastic, just put new spark plugs in my Corvette.
ThisIsLivin is offline
