Transom Tie down >
Transom Tie down
Transom Tie down
Old 09-22-2021 | 05:23 PM
Default Transom Tie down
Anyone know where I might be able to find something like this ? I was on the transom of a 24 outlaw and I used it as a tie down on trailer, but I has seen better days and was hoping to replace with something similar that is polished SS. I was hoping to replace with something similar rather than Ubolt because the gel coat came up a little around the holes when I pulled it and a direct replacement will hide the chips. Thanks in advance.
Big_Baller is offline
Old 09-22-2021 | 07:11 PM
Almost any local machine shop should be able to set you up real quick and probably inexpensive
zfrilly is offline
Old 09-23-2021 | 04:14 AM
2x2x1/4" 316 stainless steel, drill press, grinding disk ? Check metal supermarkets , they can probably cut them for you too.
carnutsx2 is offline
Old 09-23-2021 | 09:13 AM
Wally's Avatar
Were doomed!
hard to tell on the thickness from the pic but that just looks like a 2x2x3/8 aluminum angle iron that was rounded over on one side and some holes drilled....you can pickup a 2' piece of that material for around $30 and shape/drill it yourself
or find a local machine shop if you want it done super nice. You can hard-coat anodize it to help with the corrosion....or pay a bit more and go with a stainless material.
-Wally
Wally is offline
Old 09-26-2021 | 12:39 PM
Why not use bow eyes instead?
Tractionless is offline
