Blown Bravo 1
Old 10-04-2021 | 12:40 PM
Default Blown Bravo 1
I went out this past weekend and ran my boat hard. Thought I blew my drive. When I pulled it off this is what I found. I'm going to pull apart when I find the time but was wondering if anyone had any idea why this net would back out or push out?
riverrunner242 is offline
Old 10-04-2021 | 12:54 PM
Go ahead and pull out the input
shaft assy and see if any teeth have broken off of the
gears….. you don’t even need any tools to do this
JaayTeee is offline
Old 10-04-2021 | 02:55 PM
As said above. Should be able to pull the input right out.
Lost a few teeth, they tried to climb each other, pushed against retainer nut, then the threads in upper case lost the match.
cheech is offline
Old 10-04-2021 | 07:38 PM
that's what a blown upper gear case looks like !
boostbros is offline
Old 10-04-2021 | 08:18 PM
yeah looked a little closer tonight. Yikes!
Old 10-04-2021 | 09:58 PM
Oh that's not good...
What were you doing when she went? Speed, water conditions, heavy or light load?
xlint89 is offline
Old 10-05-2021 | 05:54 AM
when it went I was around 4000 rpm calm water. Boat is a 28 pantera speed I'm unsure of. Probably around 55mph. I'd say it was under a pretty light load
Old 10-05-2021 | 06:23 AM
What direction do you think you will go? XR? SCX?
MMatt28 is offline
Old 10-05-2021 | 07:03 AM
I'm thinking scx even though xr fits my budget a little better. Then I think I'll be good even if I decide to upgrade power down the road
Old 10-05-2021 | 07:42 AM
XR upper has held up for me for quite awhile after blowing two Bravo X uppers. Prices can vary widely so shop around and don't buy a used one.
thirdchildhood is offline
