MK IV Power Steering Pump Bracket?
Does anyone have pictures of the PS setup? Heck, pics of the entire belt setup would be REALLY helpful!
Built an engine for a restoration project and even with a ton of parts available to me, I can't find a workable solution that fits and am tired of banging my head on the wall.
I have the Merc diagrams from that era, but... not very helpful.
TIA
TIA
Here is what mine looks like, minus the P/S belt. The P/S belt goes from the crank outer grove to the recirculating pump outer grove to the P/S pump.
I should be at the boat tomorrow and I can give you a picture of all of them and the P/S belt number.
Hope this helps.
Hope this helps.
I have that bracket, but.... it won't fit with the exhaust manifolds that I have (water port on the front).
I have an "oddball" bracket that I found (have TONS of parts available to me; family boat yard), but it sat too far out front for a two groove pully. Guess I need a new pully. At least that is an easy fix! This bracket puts the PS pump on the stbd side.
Trying to solve a bigger problem now; where did the water in the oil come from.... #$@$#$%. Fresh build, MLS head gaskets, so I "think" I can rule out the head gaskets. Pulling the pressure tester out tonight.
Thanks!
Thanks!
How much for the pulley?
