Exterior engine saltwater  protection >
Old 11-09-2021 | 07:20 PM
Default Exterior engine saltwater protection
Moving a new to me boat from fresh to salt. Boat has closed cooling.
Motors are currently out. Considering coating oil pans with truck bediner. I've used the rattle can stuff on brackets etc in salt with great success. Also thinking about covering the lower half of the engines with Fluid Film.
Any ideas appreciated.
Mr. Demeanor is offline
Old 11-09-2021 | 08:31 PM
Bed liner… no way IMO water always gets under it unless it’s linex
good paint and keeping it clean w/ a corrosion x or similar spray works well
sailtexas186548 is offline
Old 11-10-2021 | 06:54 AM
This is what I am doing too.
F14A water jet is offline
Old 11-10-2021 | 11:08 AM
Ive used on parts submerged in salt for years with great results. Transom brackets, transom plates, trailer parts including axles, etc. LineX is tougher for abrasion but this wont see anything like that.
Old 11-22-2021 | 09:22 PM
Enamel paint. Clean parts real good. Put primer on it. Use high heat enamel. Put several coats on. I’m building an LS for salt water right now.
painted oil pan, block, front cover, rear cover, heads, valley plate, valve covers, exhaust manifolds, bell housing. In short if it was metal it got primed and painted.
aluminum gets this white oxide “rust” on it. Rust oleum makes a good aluminum primer in aerosol. And I’ve used various brands of enamel with good success. Just get a good bond to start with.
NOTE: I would not do anything to stainless.
Xcomunic8d is offline
Old 11-23-2021 | 06:30 AM
Just a decent paint should be sufficient. Excuse the mess in the bilge , just had changed the oil. Saltwater
smokediver is offline
