Triple verses Duel
Old 11-11-2021 | 07:23 AM
Default Triple verses Duel
Thought on new aluminum triple axle verses duel axle for Baja 26 Outlaw. Boats been on duel steel.
26 Outlaw Bad Influence is offline
Old 11-11-2021 | 07:25 AM
Default Triple axle verses dual
Old 11-11-2021 | 07:29 AM
I wouldnt see a need for a triple axle trailer, just more weight you have to pull.. I just bought a 10k tandem axle trailer for my 29 fountain and it is more than enough.
DallasBAJA is offline
Old 11-11-2021 | 07:43 AM
Dual will be fine as a triple would be overkill for a 26 IMHO. I have double axle under my 35.
techman is offline
Old 11-11-2021 | 08:09 AM
That boat does not need 3-axles. Why subject yourself to limited mobility, additional maintenance and extra tires to blow/replace?
Cory H is offline
Old 11-11-2021 | 08:53 AM
Dry weight of the boat is in/under the 5K lbs range.
Good tandem is the best trailer as a tri is just going to chew up tires. (hell, you can efficiently pull a 36 on tandems if it's matched properly.)
Tri axles have their place -your boat isn't one of them so save your maintenance/upkeep $$$ budget for buying a high quality tandem from the start
speicher lane is offline
Old 11-11-2021 | 09:12 AM
Rookie's Avatar
I replaced my triple 3500# axles (10,500#) out for dual 6000# torsion axles (12,000#) on my 30' Panther. Best trailer decision I have ever made.
I tore up tires on my triple making tight turns.
Best place to buy trailer axles?
Rookie is offline
Old 11-11-2021 | 09:16 AM
Dual all day long, easier to maneuver, less tires to worry about and at 26 feet you really have no need for triples. Back a triple up and make a sharp turn, you will cringe at what those tires/axles do.
Wildman_grafix is offline
Old 11-11-2021 | 04:41 PM
dual
Baja 252 Islander
bajaman is offline
Old 11-11-2021 | 07:04 PM
Scarab28's Avatar
My triple aluminum trailer floats when backing into water with no boat on it. Had to add lead weights to keep it from floating.
Scarab28 is offline
