Bravo 1 roller bearing internal gear
hello everyone, I'm looking for a way a puller to remove the roller bearings from the inside of the gear or the c-clip without damaging it to clean it properly and put it back it collects a lot of **** below the c- clip and you bearing
all stuff will be appreciated thanks for your help
yes thank you I buy them from imco when I change them I realized that a lot of debris was collected under the c-clip and between the floor of the gear and the bearing I am looking for a way to remove them without damaging them
Check the spacing between the needle bearing rollers with a thin flat screwdriver,,if there is much gap,,replace them with new bearings,, I have seen these so worn that the needle bearings actually come out of the casing ,,then bad things happen.
I have a special tool to remove them.
Not sure which bearing, but if I was going thru the trouble of taking the drive apart and cleaning contaminated bearings, I would just replace them.....
I have found with boats, every time I try and save a dollar, it costs me 100......
