Running a Blackhawk drive >
Old 12-27-2021 | 08:51 PM
Default Running a Blackhawk drive
Recently had Blackhawk 1.36 built . I’m currently running 31 p props . Tested this weekend and looks like I’ll need more pitch cause I’m over revving . Anyone know of a prop guy that has experience in these props . Thanks , Hf…
halffast is offline
Old 12-28-2021 | 12:53 AM
BBlades would prob be your best bet, but you can only adjust pitch by about 1" which will reduce about 200rpms and maybe reduce another 200rpms with added cup. You might be better off to change to 1.25 ratio gears.
If you're over revving then are you running a 100+mph ???
Griff is offline
Old 12-28-2021 | 07:39 AM
turn it up we run an 540 over 6500rpm
boostbros is offline
Old 12-28-2021 | 03:39 PM
Default Blackhawk
Was trying to keep the rpm under 6000 at full peak . I run a 598 na Eddie Young for power . I’m not exactly sure where it’s gonna stop climbing . Seems like it’s gonna go past 6500 and beyond . I just ain’t sure how far beyond ? Hf…
halffast is offline
Old 12-28-2021 | 06:07 PM
Rookie's Avatar
If it's not making power past 6000 there is no reason in the world to rev it past it. What RPM does Eddie say prop to?
Rookie is offline
Old 12-28-2021 | 07:40 PM
we run solid rollers and big valve springs we are good to 7500 the power does fall off but so does the friction of it being up out of the water and i dont care who you are a healthy bigblock at 7000 sounds awesome
Old 12-29-2021 | 12:40 AM
A Blackhawk is not gonna last very long behind that much power anyway. Save your $$$ for an SCX.
Griff is offline
Old 12-29-2021 | 08:01 AM
If that’s the video you sent me some time ago your absolutely right. Sounded wicked! The one with the not so happy fountain in your wake. 😂
getrdunn is offline
Old 12-29-2021 | 08:36 AM
getrdunn send me a text i have even better vids anyone know how to post here from text on phone?
Old 12-29-2021 | 09:12 AM
Email them to someone?
Now we're all curious. LOL
cheech is offline
