Drilling out Arctic Cat helix bolts Help >
Old 01-05-2022 | 04:20 PM
Default Drilling out Arctic Cat helix bolts Help
Got a sled yesterday with a bad secondary. Got it home and figured out what was wrong. Got everything in good shape now other than extracting the three broken off bolts in the helix. Tried drill-press and with the small bit it just wants to bend the bit. Tried heat with a pick and that’s a no go also. Any ideas. Yeah I know I come across some fked up chit bit Tks in advance.
getrdunn is offline
Old 01-05-2022 | 04:26 PM
SABER28's Avatar
try setting a small nut on top and welding it to the broken off bolt.
SABER28 is offline
Old 01-05-2022 | 04:46 PM
Got get a carbide drill bit...about 5/32", it will drill through that like butter, then you can use a screw extractor (Easy-Out).
Baja 252 Islander
bajaman is offline
Old 01-05-2022 | 04:58 PM
SB
yup, and weld won’t stick too the aluminum.
SB is online now
Old 01-05-2022 | 05:05 PM
F-2 Speedy's Avatar
https://www.harborfreight.com/left-h...yABEgIpdPD_BwE
F-2 Speedy is offline
Old 01-05-2022 | 05:31 PM
Steve H's Avatar
artselectricinc.com
https://www.ebay.com/itm/122978410906
Don't waste too much time on it! That is a wear item, and they are easy to come by
Steve H is offline
Old 01-05-2022 | 05:42 PM
make sure its a reverse drill bit
carnutsx2 is offline
Old 01-05-2022 | 05:49 PM
welding a nut is the easiest method of extraction,,do it all the time.I only drill if I need to shrink the bolt as its being welded.
sutphen 30 is offline
Old 01-05-2022 | 05:57 PM
I have removed more broken bolt with left handed drills than any extractor I have ever tried.
zfrilly is offline
Old 01-05-2022 | 06:14 PM
I’ll try the left bit. Two of them are down 5/16” so welding those two not fix unless I’m not a good welder. Tks
getrdunn is offline
