575 sci valve spring?
Old 01-23-2022 | 03:38 PM
Default 575 sci valve spring?
What’s an equivalent or upgraded spring for a 575sci? Can’t seem to find the 24-13455T spring, and it’s also pretty pricy at $35 a piece.
stock cam and everything else.
LakeHuronPower is offline
Old 01-23-2022 | 03:46 PM
F-2 Speedy's Avatar
whats the spring rate
F-2 Speedy is online now
Old 01-23-2022 | 04:09 PM
The old springs measure about 340lbs/in, springs have around 400 hours on them, not sure how worn they may be. I see plenty with a similar rate but these seem to be an odd size with an OD of like 1.45”, would rather not buy new retainers.
Old 03-28-2026 | 11:57 PM
Hi, I was wondering if you found a replacement for the 24-13455T spring? I have found myself in the same predicament, and I am having a hard time finding new springs to replace this NLA part. Any advice would help, thank you!
Formula4life123 is offline
Old 03-29-2026 | 06:44 AM
For a stock cam, you can use aftermarket 575 SCI valve springs with similar seat pressure. Make sure the spring rate matches to avoid issues.
Osiris58 is offline
Old 03-29-2026 | 07:58 AM
SB
Quick search i found this.
Hope it helps:
https://teaguecustommarine.com/flat-...8vE2aMU4QIR9Dc
SB is offline
Old 03-29-2026 | 10:01 AM
F-2 Speedy's Avatar
Hope it helps:
Yep, I run those also on the HP 500 and 500 EFI
Old 04-28-2026 | 12:50 PM
Damn, if we lived closer i would just give you my 575 sci heads, just pulled them off for swap, they only have 112hrs.
hpmaniac is offline
