Proper "ear muff" engine flush ? >
Old 04-12-2022 | 11:22 AM
Default Proper "ear muff" engine flush ?
What type of ear muff hose style do you all use or recommend?
I know that quicksilver has one that supports alpha and Bravo.
Can you use the rectangular dual feed type as well? It seems like the rectangular cups are a bit shallow compared to the more bubble shape found on the quicksilver mercury version.
I just don't want to deprive the motor of sufficient water.
Mariah212Z is offline
Old 04-12-2022 | 11:28 AM
F-2 Speedy's Avatar
A single hose connection is ample just make sure it attached securely and dont rev the engine it will suck the hose dry then you're rebuilding the pump, I think I have one dont need any more its like new
F-2 Speedy is offline
Old 04-12-2022 | 12:18 PM
Default Flush attachment
That's actually the one I have! Just wondering if those rectangular cups might be too shallow?
Old 04-12-2022 | 12:20 PM
F-2 Speedy's Avatar
you are over thinking this............
Old 04-12-2022 | 12:29 PM
SB
Only issue i’ve had with muffs is when the ears become hard after bunch of years. They don’t conform to seal outdrive well.
SB is offline
