BBC Crane/Mercruiser Cam Source >
Old 04-15-2022 | 12:16 AM
Default BBC Crane/Mercruiser Cam Source
With the demise of Crane Cams, where are the well proven “731”, “741 and 751 cams being sourced from? Who has the masters? Anyone know what lobe design was used?-Thanks in Advance.
Speed of heat is offline
Old 04-15-2022 | 12:51 AM
Very close to a 731 https://www.cpperformance.com/p-1159...ifter-kit.aspx
Very close to a 741 https://www.cpperformance.com/p-1579...ifter-kit.aspx
Griff is offline
Old 04-15-2022 | 06:08 AM
look up bullet racing cams,,they'll have what you need,,plus a great 3/4 race cam.
sutphen 30 is offline
Old 04-15-2022 | 07:18 AM
SB
As of 1/1/21, Comp Cams absorbed the little left of Crane Crams, which S&S cycle owned. Whom bought from Mikronite (sp?), which bought from Crane.
More fun facts, the same investment company that bought Edelbrock not long ago, also bought Comp Cams.
Psst: Comp does advertise a cam very similar to the 525EFI cam. It’s called Extreme Marine 525EFI. XM525EFI for short.
SB is offline
Old 04-15-2022 | 08:24 AM
The comp cam is 114 where the CP performance cams are 112
liberator221 is offline
Old 04-15-2022 | 08:37 AM
I just installed the Comp cam in my 496 build. Was the closest I could find to the 741. I was surprised Summit had 5 of these in stock too. They don't have any heads though.
https://www.summitracing.com/parts/cca-01-446-11
Tahoe540 is offline
Old 04-15-2022 | 08:42 AM
People seem to disregard the obvious choice...
phragle is offline
Old 04-15-2022 | 09:26 AM
Hold up.. I like it! That a newer comp grind? I don’t recall ever seeing it….
edit: your gonna like that much better than what you had in your 540 if I recall correctly anyway. 👍 JMO
getrdunn is offline
Old 04-15-2022 | 02:37 PM
Try calling Ron Sporl Performance Marine,(OSO member) he has a nice cam similar to a 741 he designed and has ground by Lanani. All Billet.
GLENAMY 242SS is offline
Old 04-15-2022 | 02:44 PM
SB
I was just putting general info out there in case others don't know.
Like the following,.... any cam company will grind any of their cams on different separation if you want. Just a phone call away.
And yeh, Bullet is a great company.
SB is offline
