496 cool fuel bypass >
Old 06-08-2022 | 08:28 AM
Default 496 cool fuel bypass
Hi , i have a question i have a fastech 312 with 496/s cool fuel mounted to bottom of engine, if i had to ever replace them it would be a disaster it appears, would possibly have to pull a motor. dont wanna deal with that is there a way i can by pass that by just installing electric fuel pumps that i can mount near the halon system?
bobz71 is offline
Old 06-08-2022 | 11:18 AM
You can run aftermarket pumps, but you'll also need to add a fuel cooler. The plumbing can get more involved than it's worth especially in a tight compartment with twins.
87MirageIntruder is offline
Old 06-08-2022 | 10:39 PM
TomZ's Avatar
Actually, you could plumb an aftermarket pump and send the return back the tank (the tank acts as the cooler vs the cold water tube).
TomZ is offline
Old 06-09-2022 | 09:29 AM
any pics or any suggestions on what to get? , seems confusing but man if one of those pumps craps out i dont know how ill get at it. bob
bobz71 is offline
Old 06-09-2022 | 04:26 PM
I'm running an Aeromotive marine A1000 pump with their A1000 regulator.
Old 06-10-2022 | 08:45 AM
What year 496? Gen 2 or 3 cool fuel?
Ryan00TJ is offline
Old 06-19-2022 | 03:06 PM
gen 2 just a PITA to get to
bobz71 is offline
Old 06-20-2022 | 06:18 AM
It will probably never fail as long as you winterize it properly. Don't just rely on the little air pump thingy and stop worrying about a problem that doesn't exist.
thirdchildhood is offline
Old 06-20-2022 | 06:23 AM
OFFSHOREJOJO's Avatar
496 not the greatest motors my 02! Good luck
OFFSHOREJOJO is offline
Old 06-20-2022 | 11:53 AM
Default Why?
I agree with others that you are chasing a problem that doesn't currently exist. Even if you "bypass" the cool fuels, you still have to get to them to pull the fuel lines, no?
techman is offline
