Pls look at pic of my drive gear magnets >
Old 06-15-2022 | 01:18 PM
Default Pls look at pic of my drive gear magnets
Bravo XRs. What do yall think about the metal shavings?
Michaeloh59 is offline
Old 06-15-2022 | 01:24 PM
Time to open them up and take a look. Probably flaking off of the teeth
snapmorgan is offline
Old 06-15-2022 | 03:41 PM
Have they been rebuilt recently? Any big pieces of metal on them? Are those plugs pictured from uppers or lowers?
IGetWet is offline
Old 06-16-2022 | 07:52 AM
You have pieces not fuzz, you need to inspect your gears immediately. To get that kind of buildup, your teeth have flexed so much the hardened surface is coming off. Been there and it's not fun. I had my drive rebuilt several times by AADS and after break in you will see fuzz, You can rub it between your fingers and not feel any texture. I just pulled my magnets to change my oil last weekend and they actually came out clean after 2 seasons. I had my gears cryo'd during the last rebuild, I highly recommend it after seeing how clean my magnets are.
ThisIsLivin is offline
Old 06-16-2022 | 10:20 AM
Good advice being given here. You better have them looked at.
These came off a drive that was failing and had to be idled in.
87MirageIntruder is offline
Old 06-16-2022 | 12:21 PM
I’d be betting you have gears that are looking like this
JaayTeee is online now
Old 06-16-2022 | 12:39 PM
Sydwayz's Avatar
Forum Regulator
Cris-cross Apple Sauce.
It's just a matter of time before you turn your new fluid into chunky apple sauce. It's time to pull them apart and inspect for the parts that are failing.
Sydwayz is offline
Old 06-16-2022 | 06:56 PM
Thanks Gents. Anyone have any suggestions as to a shop in the Houston-san antonio-austin area they could recommend?
Old 06-16-2022 | 06:59 PM
i just bought the boat i dont think they have been rebuilt recently. Plugs are from the lowers. I’ll ask my tech about big pieces.
Old 06-16-2022 | 10:11 PM
Surprised people are giving opinions on plug readings without smearing the metal in your finger tips to see what you got. I’ve pulled plugs like that prior to our rebuilds…looked worse than it was. Would smear it in my fingers and it dissolved.
it’s hard to tell in pics while metal is all piled up. Just my 0.02.
1MOSES1 is offline
