700sci rebuild thoughts >
Old 06-24-2022 | 02:23 AM
Default 700sci rebuild thoughts
Hi everyone
little advice would be appreciated.
I have a 700sci and while starting it would have a very slow start and then fired up. It worked fine when running. I assumed something was wrong with the engines so I pulled them, pressure tested the header and found a leak and could see they had eaten the head. Salt water boat. I opened up the engine and one cylinder had salt water and slight ruswhile all the others are fine
my mechanic has recommended to me to just polish and not bore the cylinder wall and to only change one piston for a standard size and wait for later to do a complete rebuild. He also wants to change the bearings etc.. we are also doing the top ends as the leak down showed the exhaust and intake were leaking
what would be your thoughts on this I see his point of view where he doesn’t think it’s required to do a full surgery at this point as the bottoms are fine and compression was good. Engine has 250 hours.
I have attached a couple photos
intimid8 is offline
Old 06-24-2022 | 06:02 AM
Depends on how long you’re willing to have it laid up. I’d be leaning more towards just doing the whole thing now.
Unlimited jd is offline
Old 06-24-2022 | 06:12 AM
SB
x 2.
SB is offline
Old 06-24-2022 | 06:27 AM
another 100 hours is around 3 to 4 years boating when I was planning on doing a whole rebuild which bring its to the 350 range
intimid8 is offline
Old 06-24-2022 | 07:47 AM
F-2 Speedy's Avatar
you might consider changing out the rockers also, another 700 sci
Our 2022 Cigarette Rendezvous Overview (lots of pics) - Page 4 - Offshoreonly.com
F-2 Speedy is offline
Old 06-24-2022 | 08:38 AM
Re-do the whole thing while it’s apart would be my vote. it’ll be good for another 300 hours which is 12 years by your math.
1MOSES1 is offline
Old 06-24-2022 | 09:36 AM
Looking at these pictures I'd go with full rebuilds.. spend some now or more later...
bigfarmer is offline
Old 06-25-2022 | 09:48 AM
Theyre already out ,might as well just go all the way
ICDEDPPL is offline
Old 06-25-2022 | 09:52 PM
Rookie's Avatar
Check parts supply chain and make decision if you want to boat this year.
Rookie is offline
