When to upgrade the Bravo 1? 570hp/640ftlbs
My bravo 1 is the original from 1990. Never had issues running it with a 7.4l. Short story is I’ve bought new motor pushing 570hp and 640ft pounds of torque. I boat at 6800 ft, the motor was Dyno’d at sea level. There will be a power loss. What’s going to be the way to go on the Bravo 1, 1.5 ratio? Rebuild and beef it up or put in XR internals?
boat is a 23’ cuddy cabin ( for the kids). It’s around 4klbs in weight.
quick calculation is a loss of 100hp 115ft/lbs so 470hp 525ft/lbs
I would keep running the drive as is. The older Bravos held up much better than the newer ones and the older gears were better. If it fails, I would go to Bravo X upper. Avoid going to an XR unless absolutely needed. The XR gears usually only last around 200 hrs
What's the cutoff between "older" Bravos and "newer" Bravos?
Thanks. Brad.
(937)545-8991
thx griff!
So, I'm a bit confused....
It sounds like you're saying the durability of the B1 diminished in the early 2000's, and Merc's solution was to develop several stages of stronger outdrives. But the chart shows a different story. I *THINK*. The drive on our PQ is a B1, MFRd in 2001. I'm just trying to figure out what we've got.
Thanks. Brad.
(937)545-8991
