Trim indicators
Old 07-11-2022 | 06:26 PM
Default Trim indicators
Hi all,
Looking for advice/suggestions. The K planes on my scarab do not have provisions for indicator cables. There is no way of knowing their position other than by feel and ride attitude. My question is, am I better off going with a used set of tabs that have the indicator provision and use a 33c cable set up? Or, do I go with an electric sender conversion with new dash indicator? Does anyone have experience with the electronic conversion style? Brands to shy away from? Lean towards? Also, Drive trim indicator, cable style or electronic (using merc trim sender on gimbal ring)? I'm leaning towards mechanical set ups, because I'm a believer in "keep it simple, stupid". But, I'm not sure how easy it would be to locate a decent set of used tabs that have the cable boss in the transom base plate. Mine currently do not have it. Any help would be greatly appreciated.
Thanks in advance, Chris
1983ScarabIII is offline
Old 07-11-2022 | 08:02 PM
I just had these lencos installed, all electric with a digital indicator integrated into the switch panel. Quite nice
hogie roll is offline
Old 07-11-2022 | 08:07 PM
https://www.lencomarine.com/en/p/150...-Trim-Tab-Kits
Old 07-11-2022 | 08:26 PM
you can convert k planes for indicators easily. the thru hull fitting for the 33c cable can be found at menards. You can buy the lower pins or make them if you have access to a lathe...
phragle is offline
Old 07-11-2022 | 08:41 PM
Those look nice. Adds another option.
Old 07-11-2022 | 08:43 PM
https://www.hardin-marine.com/p-1344...ng-45-deg.aspx
Is this the fitting you mean?
Old 07-11-2022 | 08:44 PM
Also, thank you guys for the input and suggestions
Old 07-11-2022 | 09:17 PM
Originally Posted by 1983ScarabIII
nope...it screws into the k plane base plate cable gland,,, like this
There is a plug near the upper pivot pin, this replaces the plug abd you drill a hole for the cable
Part number 23... though it will be 5 bucks at menards vs.....
phragle is offline
Old 07-12-2022 | 04:49 AM
I have an early base plate that does not have the 1/2 NPT holes in it.
Old 07-12-2022 | 06:12 AM
I believe these are the digital part numbers if you go that route.
Default F/S 2 K Plane electronic sensors w/harness Mercury K Plane electronic sensors (part number 863187A04), 1 harness (part number 84-895820A05), 2 L brackets that go from the sensor to tabs with bolts, and 2 stainless fittings that screw into K Plane transome plates that the wires go through (Wire grips) are needed.
I had sold this so a few years back.
underpsi68 is offline
