How to determine what exhaust I need?
There are so many exhaust options, how do I determine what exhaust I’m going to need?Custom 496 stroker motor puts out 570 hp 670 foot pounds of torque. I’m going to be redoing the air inlet and put a through transom exhaust with a captain‘s call switch to route the exhaust out into the water if it’s too loud.
Replacing my 7.4l it currently uses a wet exhaust system. Id prefer a wet system to keep the manifolds cool.
What cam?? Stainless marine is a great exhaust, What you will deal with more given healthy numbers from a 496 is the possibility of reversion, a captains call could possibly increases that risk it really depends on the build of the motor. If your motor designer/builder is a good marine guy he should be able to tell you.
From the package...
. THE CAMSHAFT IS A NEW ELGIN INDUSTRIES E1143P AND WITH A TRUE CLOYES DOUBLE ROLLER CHAIN SET. THIS CAMSHAFT IS A HYDRAULIC LIFTER GRIND .576 LIFT 246 DURATION @.050 ON BOTH THE INTAKE AND EXHAUST AND IT IS GROUND ON 108 DEGREE LOBE SEPARATION
Sorry for the caps am using my phone,. I quickly and copied and pasted this from the description
Motor delivered today...
From the package...
From the package...
This type exhaust legal for your area ?
Dimly lit minds like mine wanna know how this got delivered ? Was this ordered as a I/O marine engine of course.
