Big Block Chevy Ing Timing >
Old 10-05-2022 | 01:56 PM
Default Big Block Chevy Ing Timing
Looking for a little guidance here in regards to my ign timing map for my 468. This is an EFI engine controlled via a AEM infinity, running at 575sci blower with the smaller pulley (8ish psi) and intercooler, roller cam. Not looking for max power just reliability and a safe tune on 93. Any thoughts / concerned with this timing map ?
Big_Baller is offline
Old 10-05-2022 | 05:34 PM
yeah, way to low imop.
20* at 6K with 9lbs? How hot would those exhaust valves get holy cow.It`s not an LS
I wouldn`t be under 31*
ICDEDPPL is offline
Old 10-05-2022 | 05:42 PM
Before anyone can give a recommendation, what's the compression?
underpsi68 is offline
Old 10-05-2022 | 05:45 PM
that would be useful info . Its 8.25:1
Old 10-05-2022 | 05:47 PM
Originally Posted by ICDEDPPL;[url=tel:4847424
4847424[/url]]yeah, way to low imop.
yeah it looked low, it was just the base map but I am more familiar with Imports with higher revs and much higher boost. Thanks for posting your table.
Old 10-06-2022 | 12:37 PM
Made a few tweaks.
Old 10-07-2022 | 02:17 AM
I'm not familiar with boosted motors, but a have advanced the timing on my mefi 3 mpi by quite a bit and talk about feel like a different motor. Gained 3+ mph. I like the chart tinimg ICEDEDPPl has around the 0 manifold pressure area. Mine's actually a couple degrees higher for the same RPM/man pressure, but i do always run premium and i am not having to drive a blower either. I appreciate all the knowledge that others give on here. Thats how i started learning, along with a LOT of trial and error. LOL.
Good luck.
Cap'm Kurt is offline
Old 10-07-2022 | 10:18 PM
TomZ's Avatar
Good luck.
I remember you asking about adding timing. How much did you end up adding?
TomZ is offline
Old 10-12-2022 | 10:41 PM
tomz, stock was 29 or 29.5 but not until got righ t at WOT around approx 4800/4900 or so, I dont recall exactly, would have to look at the mefi3 tables. I went to 34 deg at 2500 rpm, 35 deg at 4800rpm. Only run premium.
Old 10-12-2022 | 11:53 PM
TomZ's Avatar
Would have been fun to try when I had it running the MPI. Totally different now.
TomZ is offline
