Kill switch
Boat is a '87 Baja Sport 220. The kill switch is not wired. Control box has yellow & yellow w/red stripe coming out the back that make the neutral start circuit. The kill switch has a purple and purple w/white stripe hanging off of it. Do I use these purple wires to interrupt the ignition "run" wire from the key switch? If not, how should they be wired?
TIA
TIA
The purple wire right off the ignition switch (run/ignition position) for the ignition kill switch. Ie:lanyard kill switch.
Or are you referencing the neutral safety switch from shifter that uses the yellow/red from ignition switch start position.
or keeping power there when driving
