Mercury 409 MPI >
Mercury 409 MPI
Mercury 409 MPI
Old 10-17-2022 | 08:55 AM
Default Mercury 409 MPI
Mercury's new 409 MPI claims to have a flat plane crank, I'm curious what advantage that gives to a boat. I also see in the pictures what looks like a Holley EFI throttle body...?
I wonder if this means Holley will be able to interact with smartcraft/vessel view stuff.
Wonder if anyone knows more about it?
LakeHuronPower is offline
Old 10-17-2022 | 09:06 AM
You might be able to spin it faster. What are the specs for operating max rpm range? I'm not convinced this is a replacement for a big block.
Pretty sure this is their 383 with some more cubes and a new crank.
techman is offline
Old 10-17-2022 | 09:46 AM
Industry-Exclusive Flat-Plane Crankshaft
what! Need some more specs if anyone knows
hogie roll is offline
Old 10-17-2022 | 12:08 PM
SB
O advantage in this application. Sub 6000 rpm small block chevy. Different noise is all.
Look up / google search flat plane crankshaft v8 advantages.
I rather wish they’d spend 5 $ and a few minutes times to make their sbc exhaust manifold water passages line up to their risers.
:rolleyes
Mercruiser. Yup, beware. Manufacturing issues.
SB is offline
Old 10-17-2022 | 02:19 PM
Mbam's Avatar
Offshoreonly Advertiser
Performance 400 horsepower 5000-5800 RPM Exotic idle quality Great acceleration Flat-plane crankshaft 150# lighter than 8.1L Speed gains with Bravo One X
Technology ECM 555 SmartCraft 10-pin harness Engine Guardian MPI fuel injection Mechanical throttle & shift
Black-X valves Dry joint iron exhaust Heavy-Duty iron block Forged crank, pistons & rods Shaft-mounted roller valvetrain Full System Fresh Water Cooling Heavy-Duty Eng. oil & PS fluid coolers
Single-point water drain 3-year limited warranty 25W-50 engine oil Long-life coolant Remote oil filter 87 octane fuel
985 pounds. List price $33,425, available next month.
Mbam is offline
Old 10-17-2022 | 02:44 PM
SB
All that For a 400hp 383 ? Nutz !
Damn.
IMHO as always.
SB is offline
Old 10-17-2022 | 03:17 PM
Need to get rid of that single point drain system
AllDodge is offline
Old 10-17-2022 | 03:20 PM
Another thought; how are they building a motor without CAT's these days? Would be great if they could, but don't see how.
AllDodge is offline
Old 10-17-2022 | 03:34 PM
Maybe this is technically a remanufactured engine and not subject to catalyst requirements?
techman is offline
Old 10-17-2022 | 03:41 PM
I also noticed that the Quicksilver 8.1 and the 540 Mag stroker are no longer available. Looks like this is your Mercury sourced replacement for big blocks with a warranty.
techman is offline
