Go Back  Offshoreonly.com > Technical > Electronics
BBC spark plug wire set >
Old 11-10-2022 | 10:38 PM
scippy's Avatar
Default BBC spark plug wire set
Time to purchase 2 good sets ~ for my BBC with AS&M EFI's ........any good recommends?....Thanks, Scippy
scippy is offline
Old 11-11-2022 | 09:23 AM
I have had great luck with JDMSpeed 10.5mm spark plug wire set for BBC (I cant post links, too new lol)
I was skeptical on the price but worked great on a 454, currently rebuilding it into a 496 and will be reusing them. The one issue I ran into was if you want to use cable combs / clips, its difficult to find ones that support 10.5mm. I ended up using 'Taylor Clamp-Style Wire Separators 42709' from summit racing and they do the job just fine
CheckmateScarab is offline
Old 11-11-2022 | 09:25 AM
I bought a set of Taylor custom 8.5mm wires as they were recommended by Daytona Sensors. Very low resistance and kit came very complete. I have a crimp tool and my layout is anything but stock so I always get the custom kits. Plus my coil is mounted further from the distributor than stock so I have to make my own. I will buy them again if and when I need new. Best part is they aren't expensive.
ThisIsLivin is offline
Old 11-11-2022 | 09:30 AM
Veteran: Army
I got the "FAST" Firewire set based on a recommendation here. Nice wires, good price
DrFeelgood is offline
Old 11-11-2022 | 04:23 PM
scippy's Avatar
Thanks all!....a set of wires with low ohms and very low resistance is what I'm after for my EFI engines...wil research all above. thanks much!
scippy is offline
Old 11-14-2022 | 08:35 AM
FST-255-2416 is the part number. Running them both on my 502MPI's, fit very nicely and about the best specs for the money.
Gimme Fuel is offline
Old 11-14-2022 | 09:53 AM
I got mine here John works directly with Moroso for custom fit marine app ones 40 ohm per foot best you will find.
Boats Unlimited | Marine Technician Service | Inspections (boatunlimited.com)
Old 11-14-2022 | 11:17 PM
scippy's Avatar
Just picked up 2 sets FAST 255-2416.......they state 25 ohms per 12"....that's just about the lowest I've seen....thanks all!
scippy is offline
Old 11-16-2022 | 08:34 AM
bigboat28's Avatar
Do these sets fit around headers?
bigboat28 is offline
Old 11-16-2022 | 09:03 AM
Veteran: Army
Yes, they fit under my CMIs without a problem.
