Marine Machine steering fittings >
Old 11-28-2022 | 08:50 AM
Default Marine Machine steering fittings
Hi, does somebody know from where to source stainless fittings to M&M hydraulic steering? Any shops to get these from south FL, between Miami - Ft Lauderdale? Thanks
DoubleH is offline
Old 11-28-2022 | 09:04 AM
TomFTM's Avatar
Latham should have them . They are in that area .
TomFTM is offline
Old 11-28-2022 | 09:22 AM
Hmm.. Tried ordering these from cpperformance, they carry Latham fitting and said they don't have right ones for M&M.
I will try Latham anyway, thank's
DoubleH is offline
Old 11-28-2022 | 10:08 AM
TomZ's Avatar
I had new hoses made for mine - Parker. They were expensive.
Could always check with Sick Stinger. He might have some hoses where you can salvage the fittings. You'll need the proper mandrel to attach the fitting to the hose.
TomZ is offline
Old 11-28-2022 | 11:54 AM
The MM fittings are not Stainless. They are SS or nickle plated brass. Brass seals better. They are also reuseable and I reused mine. Kind of a pain to get the old hose out, but applying some heat helps. You don't need any special tools. The hose literally screws onto the inner part of the fitting.
CP only sells the brass -6 JIC ones. Teague sells the SS fittings which are an IMCO part https://teaguecustommarine.com/hyd-s...parts-fittings
Griff is offline
Old 11-28-2022 | 04:47 PM
I used to get all that stuff from aeroquip in Ft. Lauderdale. if they didnt have it they could get it.
compedgemarine is offline
Old 11-29-2022 | 11:16 AM
Good info, thank you. I was stupid enough to throw the old ones away since they had some corrosion..
DoubleH is offline
Old 01-02-2023 | 03:38 AM
bencini231's Avatar
I ordered my hoses with fittings attached from Latham last year and also ordered the #6 90 degree fittings from CP. I sent the 90's to a local plating shop and had them chrome plated. Feel free to message me if you need any info.
bencini231 is offline
