Fuel tank access >
Fuel tank access
Fuel tank access
Old 12-20-2022 | 01:28 PM
Default Fuel tank access
Hey guys, How to get to the fuel tank in a Baja 252? Mine is a 1996 and I am building a new engine for it, I want to also building anew return style fuel system. I need to access the tank so I can install fuel hat housing the pumps and pickup but I dont know how the floor comes up in these boats. From looking at it the job looks like a complete nightmare??
Joeyboost is offline
Old 12-20-2022 | 01:38 PM
F-2 Speedy's Avatar
I wouldn't put the pump in the tank jmo....is there any round access covers in the floor / under the rear bench seat, I had a 272 that had them
EDIT: they could be under the carpet if there is any
F-2 Speedy is offline
Old 12-20-2022 | 02:02 PM
I just looked back at photo before I winterized it and yes one cover in the rear below the bench and one right outside the cabin. If I remember correctly the rear one is the tank float. Why do you think putting the pump in the tank a bad idea?
Old 12-20-2022 | 02:22 PM
F-2 Speedy's Avatar
I dont think its very common place in a boat, mine are mounted low in the bilge easy access if there is an issue, like I said its your build
Old 12-20-2022 | 03:36 PM
Wally's Avatar
Were doomed!
If you look at marine electric fuel pump setups, they are usually mounted close to the engine as possible.....most times with hard lines after the pump going to the engine. If the line breaks feeding the pump the check valve in the tank will stop flow and engine dies and no fuel spilled.......if the line feeding the motor on an in-tank pump setup breaks, then it will flood the bilge with gas. ...........big boom!
-Wally
Wally is offline
Old 12-20-2022 | 03:44 PM
Veteran: Army
And it's a Coast Guard requirement to have a maximum distance of 12 inches from pump to engine unless it's a transfer pump from tank to tank.
DrFeelgood is offline
Old 12-20-2022 | 05:53 PM
some pics of a 272...very similar to a 252...
Baja 252 Islander
bajaman is offline
Old 12-20-2022 | 09:15 PM
Most likely you will not have an extra port to install your fuel return line into the tank. Easiest way around this is to install a T fitting in your fuel fill hose close to the tank and run the return line to the T fitting.
Griff is offline
Old 12-20-2022 | 10:30 PM
My 1996 272 had an extra fitting and I used it as a return. Just look under the back bench round access panel. The extra fitting had a pickup tube on it as well.
tgorbett is offline
Old 12-21-2022 | 05:41 AM
SB
Many peep’s use these , or similar, for returns.
https://www.cpperformance.com/c-500-...s-returns.aspx
SB is offline
