What Are Your Trailer Must-Haves..?? >
Old 03-17-2023 | 06:21 PM
Default What Are Your Trailer Must-Haves..??
In the process of building a trailer for my 40 Skater and I'm just curious what are your must-haves when it comes to your Trailer???
bigfarmer is offline
Old 03-17-2023 | 10:45 PM
All trailers are JUNK. So build it way overkill so it holds up.
Bigger axles, brakes, bearing, suspension. You can even go way bigger on axles and run the correct suspension rating, so at least you get better bearings and brakes.
EOH Disc Brakes
Bright Reverse Lights
2 Spare wheels and Tires
Spare hub and bearing
stronger wheels and tires. Overkill. If spec is E load Range run G Load Range tires, etc.
offshorexcursion is offline
Old 03-18-2023 | 05:27 AM
offshoredrillin's Avatar
EOH brakes,14 ply tires, thicker carpet on bunks and uplighting.
offshoredrillin is offline
Old 03-18-2023 | 05:42 AM
A material other than painted steel
Disk brakes
Waterproof LED lights
Who is building your trailer, by the way?
Markus is offline
Old 03-18-2023 | 07:17 AM
Tool box!
IGetWet is offline
Old 03-18-2023 | 09:33 AM
Will be running 8000lb dexter torsion axles with EOH brakes on all 3 axles
17.5 alcoa wheels with 16 ply Continental tires
Will have 2 full spares and I like the idea of having them mounted on a spindle so if a bearing goes out I can just change the whole hub.
So far the tool box is 75x35x24
Will be putting on a equalizer systems hydraulic jack.
Trailer construction will be steel.
Building the trailer myself in my shop... ( what else is a farmer to do over the winter) I'm hoping to have it done for Boyne Thunder in July.
Old 03-18-2023 | 09:38 AM
Big Farmer - not sure who your supplier is but Cerka has been really good in the past for us. Located in MIlton, Ont.
Online Trailer Parts | Axle Manufacturer | Cerka Canada
speicher lane is offline
Old 03-18-2023 | 01:11 PM
Craney's Avatar
Any pictures?
Craney is offline
Old 03-18-2023 | 01:33 PM
Originally Posted by Craney
Any pictures?
I will post some here in the near future, I might do a whole post on the complete build.
Old 03-18-2023 | 03:45 PM
That's the exact axle and wheel tire combo I was hoping for, at a minimum.
Also look into air tight or Vault hubs.
I've heard of people sealing up and pressurizing the frame to prevent rust?
A large on board water tank to wash and or flush engines would be cool.
Pit bike racks.
Entry ladders.
I like the west coast style triangle center mounted permanent drive guard. Don't care for the gates that you have to open.
