Transom housing
Helping a buddy rebuild his transom assembly , the housing has some corrosion up by the swivel shaft seal, cleaned it up and now I am able to put the new seal in by hand anyone run into this? I hear it's kind of a common issue because the seal gets stuck on the pin, and as it turns it wears into the housing, any tricks on fixing it. Thanks.
Ayuh,..... If you can get at it with a prick punch, I've tapped a few divots in bearing/ seal seats, which shrinks the diameter enough to hold a bearing race/ seal,.....
