Electric raw water pump idea.. >
Old 04-22-2023 | 05:43 PM
Default Electric raw water pump idea..
Anyone thought about converting to an electric water pump? You’ll have to have it on a relay of sorts or you’ll back fill your exhaust into the cylinders.
Batmeat is offline
Old 04-22-2023 | 07:13 PM
articfriends's Avatar
To replace your raw water pump or your circ pump?
articfriends is offline
Old 04-22-2023 | 07:30 PM
raw water
Batmeat is offline
Old 04-22-2023 | 11:18 PM
I thought the same thing. Something that could be mounted where you could service it easily. There must be a reason no body has done it.
PQ290Enticer is offline
Old 04-23-2023 | 05:41 AM
SB
Would have to be a pretty serious electric water pump. The belt driven bravo pumps move a serious amt of water. If the bravo location is kickibg your azz and if If you have room, think about going crank mounted. Several semi recent threads on this.
SB is offline
Old 04-23-2023 | 06:26 AM
For...why? What purpose? Other than a MINISCULE reduction on parasitic drag for the ICE, what possible advantage could there be, and at what cost in complexity of the system?
Baja 252 Islander
bajaman is offline
Old 04-23-2023 | 07:11 AM
My turbine boats that had water cooled exhaust all had electric water pumps. They flowed a ton of water but were also pretty heavy. In my mind an engine mounted pump on a gas engine is a lot simpler.
302Sport is offline
Old 04-23-2023 | 08:34 AM
Complicating things that aren't complicated. Mechanical water pumps are simple, proven, and won't ignite fuel vapors.
techman is offline
Old 04-23-2023 | 08:42 AM
Im converting back to the belt driven from the front crank driven. I haven’t yet pulled the impeller from the front crank mount pump but I’d guess it’s about half the size and mass.
getrdunn is offline
Old 04-23-2023 | 09:46 AM
they make some really big front mounted water pumps
sutphen 30 is offline
