Alpha One - Replace Shift Shaft Seal >
Old 04-23-2023 | 06:29 PM
Default Alpha One - Replace Shift Shaft Seal
Our family bow rider ski/tubing boat has a slow leak coming from the shift shaft seal. How hard it this to replace?
Leaking is from # 36 in diagram
https://www.mercruiserparts.com/bam/...30862/2686/160
Shah Mat is offline
Old 04-23-2023 | 06:35 PM
SB
This is how i have done several.
kinda funny, sent this vid to close (in person) friend today also. Lol. Guess ‘tis the season
SB is offline
Old 04-23-2023 | 06:37 PM
SB
I use same method for small bearings , bushings, and such in other items too / snowblower, snowmobiles, etc
SB is offline
Old 04-24-2023 | 04:26 AM
SB
Originally Posted by JamesKemp
Replacing the shift shaft seal on a boat can be a relatively straightforward process, but the level of difficulty can vary depending on the specific make and model of your boat and the location of the seal.
Are you a computer / spammer ? I’m starting to think so.
SB is offline
Old 04-24-2023 | 02:27 PM
https://m.youtube.com/watch?v=_Rf8M_jHL-M
That's not the same seal I need replaced. Take a look at the diagram I linked, my seal is leaking gear oil. It looks like there is a complete housing available, but I can't find any info on changing it.
https://nuwavemarine.com/mercruiser-...-23-815921a20/
Shah Mat is offline
Old 04-24-2023 | 08:41 PM
SB
Oh, sorry. My bulb glows dim.
i have not done that one. Quick search i found this:
Alpha I Gen II shift shaft seal replacement | Club Sea Ray
Hipe that helps or gives you a start
SB is offline
